NI TestStand
Modify Property loader DataBase Plugin
is it possible to modify the default Property Loader DataBase Plugin? if so, how can I do it?
I want to be able to add extra columns to the Properties table of the DB to use the Filter Options with those extra columns.
Right now, I get an error if I add an extra column to the DB, I want to remove the restriction of only considering 7 columns.
(2,454 Views)
Adding Example of sequence and Database
(2,329 Views)
