NI TestStand
SW Test automation using teststand
Hello Techies,
Currently, I am working on testing the software for the brushless motor. And in testing task, now I am little confused to choose the tools for test automation. Can anyone shortly explain the process for automation testing using teststand? what tools i need to use additionally with tesstand?
info: my Motor communicates with LIN bus with NI master harware box.
thanks
(2,457 Views)
TestStand is a test executive so it can definitely test software.  I've used it for that before.  Basically you call code modules from TestStand.  Code modules are pieces of code that perform a certain action.  This, from the TS help, explains more about module adapters:
https://zone.ni.com/reference/en-XX/help/370052W-01/tsfundamentals/infotopics/module_adapters/
Ideally the code modules just go and collect the data and then you let TestStand perform the evaluation.  Other things that you get from TestStand:
Development Environment
Sequencing
User Management
Abstract Report/Database logging
Multi UUT Testing (if needed)
User Interfaces
Industrial support where hundreds of companies are using it
and much more.
I've seen people make entire careers out of creating their own test executives from scratch when they could have just bought one, in this case TestStand, for much less.
If you have specific questions about your application don't hesitate to post on the forums.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,411 Views)
