NI TestStand
Modify Report File Name
I'd like to modify the default filename format in the report  options utility.
The default is SeqFileName_Report[Time][Date]_00001.xml.
I'd like to add a variable to the string
SeqFileName_Report[TestPoint][Time][Date]_00001.xml
Which callback to I need to use to modify that and how do I do it?
Curt
(3,156 Views)
Accepted by Curt_C
Howdy Curt,
I'd take a look at the documentation below for how to alter the report file path with expressions.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019RwESAU&l=en-US
Tyler O.
Applications Engineer
(3,131 Views)
