NI TestStand
Modify the Report "UUT Report" Header
Is there a way to modify the "UUT Report" at the top of the report?  I am producing two reports, one is complete with all results, the other will only have failures.  I don't want there to be confusion when this report is disseminated (and of course, there will be).
I don't see where that is set; or is it in the Stylesheet?
(2,335 Views)
Accepted by Jed_Davidow
Hi, I think it depends which kind of Report you are using.
For the ATML Reports there are Sylesheets under "C:\Program Files (x86)\National Instruments\TestStand XXXX\Components\Models\TestStandModels\ATML\StyleSheets" which you can modify (make a copy of them and modify).
But there is a good Documentation how to do that:
https://www.ni.com/de/support/documentation/supplemental/08/teststand-report-generation-and-customiz...
https://www.ni.com/docs/en-US/bundle/teststand/page/customizing-atml-test-results-6-01-or-5.html
Best regards
(2,280 Views)
