Modulus in a If Condition
i have some problems with the Modulus Operator in an If condition:
The function of the if branch should be processed every few seconds (parameter.interval).
For example, every 10 seconds for <-> if(TimeDelta % 10 ==0). <->
The TimeDelta counts the seconds for the function to be executed.
I would be grateful for any help
(1,950 Views)
Accepted by Code_Salad
OK, I found the solution myself.
The seconds() command returns a floating point number, I thought that by defining the associated variable as INT and storing the value in it, I would have an integer. To the best of my knowledge, this is not the case.
I have solved the problem by using the round function and rounding to the nearest integer, so I get whole residual numbers and my Modulu operator works.
But it would still be worth knowing why the variables that are created as INT (and also displayed as such, without a comma value!) are nevertheless stored internally(?) as floating point numbers.
Cheers
P.SI found the solution myself by passing the variables into LabView and there it was immediately apparent that they were floating point numbers after all.
(1,935 Views)
Just because you display the values as an integer (no decimal places) does not mean they are stored as integers.  As far as I am aware, all numerics in TestStand are floating point values.
(1,927 Views)
You can create integer numeric variables. Create a number and then right click on it and choose from the Representation submenu.
(1,911 Views)
