07-14-2008 03:50 PM
07-15-2008 12:36 AM
Rafi,
Did you forget to attach the error message?
What version of TestStand are you using?
Regards
Ray
07-15-2008 01:36 AM
07-15-2008 02:12 AM
Hi Rafi,
You started your post "I get this message when the Sequential model calls ...",
As I couldn't identify what was the message you were getting, which I why I asked if you had forgot to attach some JPG to the post.
Regards
Ray
07-15-2008 03:28 PM
07-16-2008 11:06 AM
07-16-2008 02:57 PM
Hi Rafi,
Do you override the ModifyReportEntry sequence in your SequenceFiles or has anything been added to the ModifyReportEntry sequence in the SequentialModel.seq or the ReportGen_html.seq file.
(this sequence should be empty if its the default one.)
Have you changed any of the ini files in the Language folder.
Have you tried searching the TestStand 3.5 folder for Mofify?
Regards
Ray Farmer
