NI TestStand
Operator interface memory leak
Sorry, but my English is not very good.
I have a big problem with my Interface Operator. The memory used by the executable increases according to executions.
I joins(contacts) the code of my Interface Operator.
  Thank you in advance for your help(assistant), because I am really clamped...
Larthomas Freddy
Développeur Labview TestStand
(3,378 Views)
Thanks for coming to National Instruments Discussion Forum.
Can you give us more details about your application? Basically, I can’t find your main VI for your User Interface. Can you also give us the different steps to do to run your application and reproduce your problem?
Generally speaking, your code on your block diagram have to be displayable in one screen.
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(3,279 Views)
