‎05-02-2019 03:30 AM
Hello.
when using the MultiUUT feature of Teststand - do the FileGlobals then exist 4 times and can have different values while executing?
Solved! Go to Solution.
‎05-02-2019 04:31 AM
Have you got All Executions Share the same FileGlobals if yes then No. If you are using Separate FileGlobals setting, then you will have n number of FileGlobals for n number of executions.
‎05-02-2019 04:47 AM
Hi Ray,
where can i set this to specify "All Executions Share the same FileGlobals"?
Thx
‎05-02-2019 05:17 AM
In the SequenceFile properties dialog
Select Edit»Sequence File Properties from the toolbar. In the Properties dialog, select the All Executions Share the Same File Globals option from Sequence File Globals drop-down menu. Click OK to register the change
