NI TestStand
MultiUUT and FileGlobals
Hello.
when using the MultiUUT feature of Teststand - do the FileGlobals then exist 4 times and can have different values while executing?
(2,270 Views)
Have you got All Executions Share the same FileGlobals if yes then No. If you are using Separate FileGlobals setting, then you will have n number of FileGlobals for n number of executions.
Regards
Ray Farmer
(2,254 Views)
Accepted by topic author OnlyOne
Hi Ray,
where can i set this to specify "All Executions Share the same FileGlobals"?
Thx
(2,251 Views)
In the SequenceFile properties dialog
Select Edit»Sequence File Properties from the toolbar. In the Properties dialog, select the All Executions Share the Same File Globals option from Sequence File Globals drop-down menu. Click OK to register the change
Regards
Ray Farmer
(2,248 Views)
