NI TestStand
Multiple Numeric Limit Hide "Unused" Outputs In Test Report
I have a question relating to Multiple Numeric Limit Test and output report in ascii txt format:
Sample Measurement, this is what I see in the txt file:
 Measurement[74] :
              Limits:
                 Low:             4.75
                 High:            5.25
                 LowExpr:         ''
                 HighExpr:        ''
              Units:              V
              Comparison Type:    GELE (>= <=)
              CompExpr:           ''
              UseCompExpr:        False
              Data:               5
              Status:             Passed
Is there anyway I can hide or "not include" the unused portion of the output?  In this case I don't need LowExpr, HighExpr, CompExpr and UseCompExpr.  It will make the report cleaner and easier to navigate...essentially this:
 Measurement[74] :
              Limits:
                 Low:             4.75
                 High:            5.25
              Units:              V
              Data:               5
              Status:             Passed
Mike
(3,829 Views)
I see the following when I create a new multinumeric limit test:
Multiple Numeric Limit Test:   Failed
     Measurement:
        Measurement[0] (Measurement 0):
           Limits:
              Low:             9
              High:            11
           Data:               0
           Status:             Failed
        Measurement[1] (Measurement 1):
           Limits:
              Low:             9
              High:            11
           Data:               0
           Status:             Failed
I think it's supposed to work exactly like you are wanting it to. Perhaps there is some issue with how the step involved was created or modified or converted. Can you reproduce this problem with a newly created and specified step? Also, please specify what version of TestStand you are using.
-Doug
(3,821 Views)
Hmm, I think I am closing in on what is going.
Doug, if I just do a normal call to multi lim test I get the same result as you.
However, I am using a code an user posted on this forum which allows you to load an array of results and limits:
I am trying to figure out what is in here that is causing all the "extra" outputs.
Mike
(3,805 Views)
Accepted by topic author mwcmwc
You are probably missing a flag that is supposed to be there for some properties (i.e. PropFlags_DontCopyToResults). I can't see enough details in your screen shot to see why it's happening, but if you make the middle column bigger or post what all of the expressions are you are using, I might be able to see what's going on. You can manually/programmatically readd this flag to some of the properties, but it should really be set by default on the expr properties already so I'm not sure why it isn't in your use case. The steptype itself sets the flag at runtime on the LowLimit and HighLimit as needed for the case in which only one or neither limit are used. It's generally expecting the flag to already be set the other properties that need it at edit time.
You can look through the source code at:
TestStand\Components\StepTypes\CommonSubsteps\
to see how the multinumeric limit step type sets the flag.
Hope this helps,
-Doug
(3,793 Views)
Sorry for the late reply.  I think this will work!
Mike
(3,754 Views)
