NI TestStand
"Disable tracing" as part of custom step type behavior
Hi !
Currently writing custom step types based on sequences (my step type's default adapter is a sequence), I would like to set the "disable tracing" right in my step type definition.
The problem is that this option isn't visible in the 'Default Run Options" tab... The only way I found to do this is using Pre and Post Expression to set 'ThisContext.Tracing = True /False'.
But I don't like the fact to use Pre/Post Expressions in my step type (I would prefer to let it blank for end users).
Is there any way to achieve this without using Expressions ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(4,298 Views)
Accepted by topic author CyGa
Hi zyl7,
In your custom step type, set the property TS.SData.Trace to "Off" (without the quotes).
Hope this helps.
-Jack
(4,292 Views)
Hi Capt Jack !
I'd love to, but how do I do this from the step type defintion ?
(4,290 Views)
In the Types definition for your custom step type, just click the '+' to open up the subproperties of that custom step type definition. You should then see the Root TS container, just follow the subproperty path to the Trace subproperty.
(4,288 Views)
Here a printscreen on the properties available for my custom step... No TS container...
Am I missing something ?
(4,286 Views)
Kinda; Open the Station Options, select the Preferences tab, and enable the 'Show Hidden Properties' option. The TS container will then magically appear!
-Jack
(4,282 Views)
Works fine !
Thank you very much !
(4,265 Views)
