NI TestStand
My ATML reports are not readable on other computers using Internet Explorer.
I am generating ATML reports using TestStand.  These reports are saved as .xml files.  I can open the reports just fine on my computer using Microsoft Internet Explorer ver. 6.  But when I send the report to another computer, the report cannot be opened and I see the following message shown below:  Is there anyway to make the reports readable on all computers using Internet Explorer?  Thanks.
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
The system cannot locate the resource specified. Error processing resource 'file:///C:/Program Files/National Instruments/T...
(4,571 Views)
Hi
The message basically states that IE cannot load your stylesheet specified in the XML file.
To fix this issue always use the TestStand tools menu item - "Package XML/HTML Files for Distribution" to 'pack' your XML reports before you try to use it in another computer.
For more details please refer to this KB - How Do I View TestStand XML Report Files On Another Machine?
Regards
Anand Jain
(4,569 Views)
Anand,
Thank you.  Your suggestions were very helpful.  However, when I tried using the XML Packaging Utility, I recieved the following error message when I clicked on the Pack button:
Type '{http://www.ieee.org/ATML/2006/Common}double' is not found in Schema.
Do you have any incite into what this means and how to correct the problem?
Thanks again.
epsilon-delta
(4,543 Views)
Epsilon,
Please contact NI support to get a fix for this issue.
Btw, What version of TS are you using?
Regards
Anand Jain
(4,531 Views)
I am using TestStand 4.1.1.
(4,527 Views)
Epsilon,
What happens when you employ option 2 of the solution mentioned in the KnowledgeBase article that Anand referenced?  That is, what happens when you create the same path/directory structure on the other machine and manually move the stylesheet files accordingly?
(4,509 Views)
Also Epsilon,
With regard to the issue you were experiencing with option 1, I want to thank you for reporting the behavior you witnessed.  As a result, this behavior will be addressed and repaired in the next released version of TestStand.  Thanks so much!
(4,471 Views)
