NI TestStand
StationGlobals.ini
I have create a copy of the UUT_Results table and added a number of columns to it. The easiest way I found to to update these columns using the Schema was to use Station Global variables that are set during test execution. Maybe this is considered very bad practice? I don't however want these station global variables in all my test sequences.
Is it possible to use different StationGlobals.ini files per test sequence.And if so please advise how?
Thanks & Regards,
Don1.
(3,042 Views)
Globals that are specific to a file are called "FileGlobals" (kind of obvious name) and it seems to me that is what you should be using. Have you ever opened a seeunce and clicked on the Variables tab? The FileFlobals are listed right above the StationGlobals.
(3,037 Views)
