NI TestStand
My TestStand / LabVIEW project is done and ready to be released.... Need help please
Yes I did.  Here is the best way i found.  (may not be the best but it is what worked for me.)
- As mentioned previously, make sure all VI's are of the same labview version
- Leave the VI's as-is.  Dont compile them or anything
- Use the simple operator interface provided by NI.
- Run the interface and point the sequence file path to the seq file you created.
- Your startup program can be a shortcut pointing to the NI provided simple OI.
- You can then install only a deployment license or debug license from NI and remove the developer license. (or just keep the developer license if you do not need it anywhere else.
All of what i said above will only work if you have labview and test stand installed on the target PC.  It must have the runtime engines to be useable.
There is a way i believe to package this and install on a PC that does not have labview and teststand, i just have never tried that.
Message 11 of 12
(971 Views)
I need to do a deploy for a new pc for an out of town customer.
I understand license fee, that is not an issue.
I just need to create installation CDs or deployment CDs.
Message 12 of 12
(964 Views)
