NI TestStand
NAN
How do you evaluate NAN in Teststand.  Using a 4070 and measuring an open circuit..infinte.  This is legit.
Do I need to eval in Labview then send pass/fail up to teststand??
(4,507 Views)
Accepted by clint100
What I have done is look at the Overrange? output of the DMM.  If it is true, then I set the ouput of the VI to something really big (like 100M).  You should be able to do simple comparisons with that.
(4,505 Views)
Yup... thanks!
(4,494 Views)
Teststand does support NAN.
You can use NAN or INF whichever is applicable.
You can use them in the numeric limit test checks ex locals.x == NAN or locals.y!= INF
(4,442 Views)
Wow, really??  Thanks.
(4,429 Views)
