NI TestStand
.NET method Side by side configuarttion is incorrect
Problem: I have sequence file that calls the following .NET method but continue to recieve this Error: The .NET method 'connect' threw an exception. The application has failed to start because its side-by-side configuartion is incorrect. Error Code: -17500.
I would like to know what steps to take to resolve the issue.
(4,256 Views)
What .NET code are you trying to call? It sounds like it might not have gotten installed correctly.
-Doug
(4,226 Views)
