NI TestStand
TestStand Notification Examples
Attention all you TestStand gurus.  Does anyone have any good examples using Notifications in TestStand?
I am using the SequentialModel sequence file.  I am calling a new thread from my Main Sequence that Polls a device continously (every 100ms).  This thread is called "Polling Sequence."  I want to be run my Main Sequence at the same time but I also want to be able to shut down the "Polling Sequence" using a notification test step called from my Main Sequence.  I also want to be able to startup again the Polling Sequence from time to time from my Main Sequence.
Does anyone have good examples for this?  Is there a better way to do this?
Thanks!
(5,784 Views)
this might help you
https://decibel.ni.com/content/docs/DOC-34743
CLAD, CTD
(5,777 Views)
