NI TestStand
NI MAX Devices and Interfaces Missing Start/Landing Page for each Device
Hi all,
I'm not sure which board to post this, but since the workstation uses NI TestStand, I used this board. When NI MAX is loaded, and the Devices and Interfaces group is expanded to show the various devices/interfaces. All good so far.
However, when I proceed to click on each device, the panel/landing page to the right goes dark grey. When you click on Devices and Interfaces a landing page shows up with details about that group. Not so for each device. I tried resetting all configuration and restarting. No such luck.
What can I do to resolve this so that I can see each device/interface? A second workstation with identical devices work fine so it appears to be specific to this one workstation.
Screenshot showing this "dark grey" behavior.
This is on the second workstation and shows it's working fine:
(457 Views)
You're right, this issue has most probably nothing to do with TestStand 😉
FIrst thing I would try would be to compare the installed software packages between the OK-TestStation and the problematic one.
If no differences show up, I'd try repairing NI May and the drivers on the problematic one.
(415 Views)
