NI TestStand
Python Adapter errors when using files from src dir
When I restructure my Python code so that I could build wheels and source distributions using a nested dir structure
pyhydraulics
src
pyhydraulics.py
pyhydraulics.yml
__init__.py
tests
pytests.py
setup.py
pyproject.toml
README.md
requirements.tx
Before all files resided in the top level dir and TS 2023 Q4 worked correctly.
When going to this structure, it creates a namespace with src. prepending the filename and errors on every import.
Is there an issue with using a src dir that I am not aware of?
The Python community goes back and forth between saying to use src of module name such as MyPackage. Since I am using setuptools where it is recommended to use the src dir.
Randy
Message 1 of 1
(686 Views)
