NI TestStand
NI USB6525
请问我可以使用NI USB 6525 来实现电压/电流的采集并记录下来吗?
(987 Views)
Hi yangle1213
Yes, you should write code (it can be LabVIEW code for example) to read data from your hardware and test it from TestStand.
Regards)
(938 Views)
Thank you very much for your answer. As a beginner, I only know how to write programs using Labview, but how to burn the program into NI devices, can you please answer it? Then, USB 6525 can continuously collect voltage data?
(931 Views)
You do not program the NI DAQ devices, instead your LabVIEW code will communicate with the NI DAQ to perform actions.
Santhosh
Soliton Technologies
(923 Views)
You should connect the hardware to your PC and check it from NI MAX (you can test it from NI MAX as well to see is it working properly) and then call the hardware from LabVIEW with DAQmx drivers (you must have compatible driver too).
This documentation can help you implement your project.
Regards)
(904 Views)
