NI TestStand
NI session manager question
I use NI session manager to control instrument,when I get the instrumenthandle and  can testing .but my question is :
if I close instrument power and not close NI teststand,but the teststand can run sucess ,my dll document run in demo.
but I think there must be a error ,and the dll return value is 0. in fact ,if the instrument closed, the return value maybe a negative.
how can I deal with it ?
(4,339 Views)
Hello Sean,
This post was recently brought to my attention.  It appears you may have posted earlier in October.  Are you still experiencing this issue?
(4,230 Views)
thank you very much ,the problem is still not sovled,In fact ,I can't  find out where I can change,it seems that teststand can run in demo if I shut down the instrument power under test,I hope the teststand can send out a caution or abort the test,but it does nothing.
 thank you no matter you can help me or not  。
(4,215 Views)
Hello Sean,
I want to make sure I fully understand your question.  Do you have a DLL that you are calling in your TestStand sequence as a code module?  If so, does a function within the DLL return a negative number if the instrument is not powered?  Is your overall question how can you determine whether the return value from the DLL is negative and make a decision based on this result?  Thanks in advance for these answers!
(4,189 Views)
that right, If I shut down the power,and the return value is not 0,negative or positive is not I need,so how can I deal with the return value?
(4,177 Views)
Sean,
You should be able to maintain a local variable to receive the return value from the DLL and then make decisions based on its value in later steps in your sequence.
(4,163 Views)
