NI TestStand
when will be the ste call backs be executed
 Hi ppl,
when will be the step call backs like SequenceFilePostStep, SequenceFilePostStepFailure,SequenceFilePostResultListEntry be executed.
will it be after status expression evaluvation or after post action ?
(3,556 Views)
Callbacks containing "PostStep" in their names will be executed after the step's execution. The first part of the callback name describes the valid range of execution (e.g. SequenceFile vs. ProcessModel).
So the execution of the callbacks take place "in between" two steps, the first one is finished completly and the second step not started yet.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,552 Views)
Check out the Step Execution Table 3-4 in the TestStand Reference Manual chapter 3-14.
There are all called after the Status Expression but I think the SequenceFilePostResultListEntry Engine callback is called after the Post Action on step 32.
Regards
Ray Farmer
Regards
Ray Farmer
(3,551 Views)
Does this mean that only the post step result entry callback is executed after post action, and other callbacks are executed in between the status expression and post action...?
(3,549 Views)
That's correct.
Regards
Ray
Regards
Ray Farmer
(3,547 Views)
