NI TestStand
NIMAX sees Labview runtime installed but Test Stand config doesn't see it
I installed labview 10 runtime, restarted the computer, opened NIMAX and Max sees it.
But on my 2017 test stand, when I go into the Labview adapter Configuration menu and look at the runtime dropdown, it doesn't appear.  Other runtimes appear but now labview 10 runtime.
Why?
(1,239 Views)
Accepted by kzamora
I hope this compatibility article helps - https://www.ni.com/en-us/support/documentation/compatibility/18/teststand-compatibility-with-labview...
In short, it looks like TS2017 supports LV2014 - 2018
Santhosh
Soliton Technologies
(1,222 Views)
Based on documentation, that sounds reasonable.
What is interesting however, if you look closely at the runtime adapters picture I included, you see runtimes for 2013 and 2011 in the supported list??
You would think those runtimes should not be listed.
But I will take your answer as that is what the documentation says.
(1,220 Views)
