NI TestStand
Need to skip the NextUUT or Continue pop up when pressed cancel
I have a Test Model in which first I ask for a model number, then serial number and then the sequence goes on testing the entered model and it goes on asking the serial number after every test. I have a cancel button in my serial number dialog box. But when I pressed cancel button the sequence shows Terminated message and after that a dialog box with two buttons " NextUUT" and "Continue".  I want to skip these two whenever I press cancel button in serial number dialog box.
(2,090 Views)
Use precondition in " NextUUT" and "Continue" Step and skip these step according to your input.
Kuddo welcomed
CLAD-CTD
(2,066 Views)
