NI TestStand
change tab position UUT batch
In the production we want to enter the serial number in the batch dialog by scanning.
Now we have a problem because if we scan the serial number, it will jump to the "Disable TS FOR NEXT RUN".
I have looked in the CVI code of the 'modelsupport2' but could not find a way to change the 'Tab Position'.
The buttons will be programmatically added but where can I change the 'Tab position'.
gr,
Bart
(2,704 Views)
Accepted by topic author InspectorGadget123123
Just found the solution.
Changed the ctrlIndex add by 5.
static int TabToNextTabbableTestSocketCtrl(int childPanel, int startingTestSocketIndex, int startingCtrlIndex, BUUT_PanelData *panelData, int tabbingForward)
int testSocketIndex = startingTestSocketIndex;
int ctrlIndex = startingCtrlIndex;
int retval = FALSE;
if(tabbingForward)
ctrlIndex=ctrlIndex+5;
if(ctrlIndex == kTSCtrl_NumCtrls)
ctrlIndex = 0;
testSocketIndex++;
if(testSocketIndex == panelData->numTestSockets)
goto Error; // Do not wrap!
else
ctrlIndex=ctrlIndex-5;
if(ctrlIndex < 0)
ctrlIndex = kTSCtrl_NumCtrls - 1;
testSocketIndex--;
if(testSocketIndex < 0)
(2,694 Views)
