NI TestStand
Needing to convert a local "numeric" value to a string type using the expression browser.
I am trying to convert a "numeric" local value to a string through the expression browser in order to supply a string arguement.  I am currently looking through the expression browser options, but I can not find any type of Number "ToString()" function.
(16,814 Views)
Str() function
ie
locals.tostring = Str(locals.dec_value)
Regards
Ray Farmer
(16,811 Views)
Accepted by mcfrenzy36
Hi you should try this:
Str(locals.MyNumeric)
Regards
Rodéric L
Certified LabVIEW Architect
(16,810 Views)
Also you can pass as format string as well with this function. checkout the help for this function
Regards
Ray Farmer
(16,806 Views)
