Hi Nick,
Fortunately with TestStand, changing the format of your reports is fairly straightforward. If you look at a sequence in your process model called "TestReport", you can see that there are a series of sequences that control how the file is generated. So what you can do is modify these calls to call your own sequences that will generate reports. For XML reports, the sequences that are called by default are in reportgen_xml.seq. I would recommend copying this file and making any changes you want to it, and then also doing the same for your process model. You can use your custom process model to call your new report sequence, and it will generate the XML however you see fit.
As for sending it on the network, you will have to make a generic code module t
hat can transmit over the network to your desired location. You can then add this step into your process model so that it submits it after any execution.
