No sequence is getting terminated . Help needed
hi All
i recently installed TS 2012 evaluation version .Previously I was having it but it got expired so i uninstalled it and again installed it.
While launching I was getting some COM error .So I searched in the forum and got the solution to make the current version active in Teststand version selector.
After which sequence editor is getting launched but I was getting error popup "Program Error" .
I again unistalled TS and installed it again. Smiley Sad
Now I am not getting that COM error neither that error popup saying :Program error"
But now My none of the sequence are getting executed properly.
It gets hang on the first step itself and not executing further.
 I have to terminate it manually.
Even if i create sequence with simple message popup it is getting stuck at message popup step.Smiley Surprised
What went wrong?
Please guide me.
(4,161 Views)
Accepted by LV_user1
Hey LV_user1,
When you say it hangs, does it seem to go into debugging mode? On the Execute menu there is an option to "Break at First Step". If this option is checked, the sequence will always stop at the first step to allow debugging.
(4,155 Views)
hey Daniel,
That was quite simple than i thought.... its working fine now.
I was not aware of that option.
Thanks a lot.Smiley Happy
(4,147 Views)
