NI TestStand
No test step data being stored in database
I have aproblem where I am using SQL Stored Procedures to save test data into an SQL Server, but although the UUT_Result table is being populated with the correct information noneof the other tables seem to be populating.
I have used this schema setup on another TestStand program and it worksOK there. Any advice or thoughts would be apprecited
Cheers
Stuart
(3,106 Views)
Hi Stuart,
We'll probably need some more information to have an idea what might be going on.  What is different about the working TestStand program and the other (version, configuration, etc)?  Are we talking about the same database?
Best Regards,
John
John Passiak
(3,069 Views)
