NI TestStand
Users.ini have some privileges set and when copied to the Test Stand cfg folder, Applicatuion is not recognising
Hi
In Our Application,Users.ini have some privileges set and when we try to copy the cfg folder from other system and paste in the Test Stand cfg folder of our PC,
our Applicatuion is not recognising it. If we delete Users.ini and StationGlobals.ini and create the same privileges again, then its working even though both the Test stand Versions are same.
Is there any Specific Reason why ot doesnt work previously?
Charu
(3,429 Views)
Are you just copying the Users.ini file from one PC to another?
What version of TestStand are you using?
Regards
Ray Farmer
Regards
Ray Farmer
(3,426 Views)
Hi Ray Farmer
 We are using Test Stand 4.0 and we copied the Users.ini file and StationGlobals.ini to the cfg folder.
Charu
(3,388 Views)
