NI TestStand
Not able to drag and steps
HI Ppl,
I was modifying the full featured user interface LabVIEW code. No I find that I'm not able to drag and drop steps in the sequence file steps view. And also I'm not able to drag and drop steps from the insertion palette to the sequence file view. I couldn't figure out which part of the code is controlling this function. Please help me fix this.
(3,884 Views)
Are you launching your application with the /editor command line or setting ApplicationMgr.Editor = true?
(3,854 Views)
HI James,
I think you narrowed down the problem. I'm actually setting the modes at run time. After that application starts the it could set the editor to TRUE or FALSE according to the need without restarting the application. I found that if I start with IsEditor property as false, then set it to TRUE drag and drop is not working. However if I start with IsEDitor as TRUE it works fine.
(3,795 Views)
Hi Ppl,
Has anyone faced such a problem. I'm not able to solve this issue. It doesn seem to be repeatable. But occurs quite often. When I checked the Editflags property of the sequence file view they are set to 63. Which is the value to enable all actions including drag and drop.
(3,746 Views)
