NI TestStand
SequenceFileDiffer.exe opens only sequences with .seq extension
Hi Ppl,
I have to save the sequence files in xml format. So I have changed the sequence file format to xml and I save them with .xml extension instead of .seq.
Now its necessary that I have to also use the sequence file diff tool for these .xml extension sequences. I found out that this tool allows only .seq sequences to be opened, because the file dialog pattern is set to .seq and there is no all files option. Is there a way to open these .xml files. I'm hoping that there should be some command line arguments that will enable this option.
(3,603 Views)
This might not be ideal, but if you type:
in the  File Name edit control of the open file dialog box and hit return it will then show you all files.
You can even do:
*.xml
to see xml files only.
Hope this helps,
-Doug
Message Edited by dug9000 on 04-15-2010 09:21 AM
(3,588 Views)
