NI TestStand
Object Reference into Array of Result
I have a DLL that use the ResultList Array  to generate xml file.
It works fine with sequentialModel.
But doesn't work with parallelModel since the result of the test is contain in the object Reference Parameters.TestSocket.MainSequenceResults.
I try to derefence it as Locals.ResultList = *Parameters.TestSocket.MainSequenceResults but it cause a run-time error.
How do I convert the Parameters.TestSocket.MainSequenceResults to an Array of Result to match the one for sequentialModel?
(2,486 Views)
JTTest1997,
I believe you will actually need to replace "*" with "&".
(2,438 Views)
