NI TestStand
Objective Question
Handle operations for a specific UUT in a custom process model?  (True or False)
I need a detailed Explanation
(2,300 Views)
I would advocate that if it is possible go for a common process model and override the process model parts you need to change by adding callback sequences to your UUT specific sequence file.  If you can't achieve what you need through overriding then a separate process model may be the way to go.
(2,284 Views)
