11-06-2017 01:43 AM
Handle operations for a specific UUT in a custom process model? (True or False)
I need a detailed Explanation
11-06-2017 03:18 AM
I would advocate that if it is possible go for a common process model and override the process model parts you need to change by adding callback sequences to your UUT specific sequence file. If you can't achieve what you need through overriding then a separate process model may be the way to go.
