Obtaining the pass/fail boolean result from a Numeric Limit Test
Requirement
From my main sequence, I'd like to call a subsequence of steps. If any of the tests in the subsequence fails, the main sequence should skip all remaining tests for this UUT.
Plan
I was planning to have the subsequence return a boolean flag back to the main sequence, which would check this flag and skip to the Cleanup step group if necessary. Most of the subsequence tests are done in a loop, so I was thinking of this approach:
bool allPassed = true;
foreach (itemsToTest) {
    allPassed = allPassed && currentTestResult;
return allPassed;
Issue
While this is easy to do with a Pass/Fail test, I couldn't find a way to get the boolean result of a Numeric Limit test.
Questions
  1. Is there a way to get this boolean result?
  2. Is there a better way to fulfil my requirement?
Thanks!
Certified LabVIEW Developer
(5,469 Views)
Accepted by JKSH
Using Post Actions would be so much easier.  You can setup the sequence to do various things on a failure, including going to a step that you specify (ie Cleanup).
(5,459 Views)
You might also consider using the station option "Goto cleanup on sequence failure" instead.
-Doug
(5,450 Views)
Thanks for your suggestions, crossrulz and Doug.
I had missed a key point: A sequence call is also considered a "step" which can pass/fail. That sure makes life easier! 🙂
(5,433 Views)
