On-The-Fly Reporting with Multiple Threads
I have a Teststand application that uses a Parallel Model along with reportgen_xml.seq for report generation. If I have a Teststand application that has multiple threads running at the same time, will there be any issues in capturing the results from those threads if I enable "On-The-Fly Reporting" option?
Shreya
(1,144 Views)
Accepted by shreyapatel
"On-The-Fly Reporting" option is designed to support multiple threads running in parallel and collecting results.
Anand Jain
NI
(1,134 Views)
Hi Anand,
Thank you for your response!
Shreya
(1,129 Views)
