Operator interface does not Tile Executions
Hi Cole,
Thanks for jumpin in.  See my original post.
mike
Message 11 of 13
(1,345 Views)
Ha,
Sorry Mike, I can kind of be an idiot sometimes.  Glad you've already seen that example though. 😉 Now that I've got a little more coffee in me I'll dig into this a little furthur.  Have you (or someone on the same system) edited your process model? Without digging into it, this seems like the most likely cause.  I'll post back when I've got something else for you.
ColeR
Field Engineer
Message 12 of 13
(1,342 Views)
No problem.  You're not the only one that needs coffee.  I've been ignorant of a few things at the beginning of this post too, but I'm at the point now where I think that the only way to get my own dual display up and running is to make the changes to one of the examples.
My best option right now is
http://forums.ni.com/ni/board/message?board.id=330&message.id=14717&query.id=169010#M14717
It's going to be a lot of work, and I expect that my early work will be plagued with bugs.  I am not familiar with the TestStand API.  But any additional information you can add to what's already been submitted, along with the above would be greatly appreciated.
Message 13 of 13
(1,338 Views)
