NI TestStand
Operator interface execution window is not getting activated-cant terminate,abort
Hi all,
I have sequence running in the operator interface which pops up a panel.It remains visible for some time and the value in a control of the panel is getting updated periodically .It is done using threads.After the panel pops up, until it goes off i am not able to operate with the controls in the operator interface execution window(terminate,abort,break).I changed the floating style of the panel as 'active when clicked on'.
Radha R
(3,325 Views)
Radhu,
Is this panel part of the Operator Interface or a dll function call from within your sequence. It sounds like its modal to the operator interface.
Regards
Ray Farmer
Regards
Ray Farmer
(3,319 Views)
Hi Ray,
You are right.It is operator interface window which is not active.
Radha R
(3,311 Views)
