NI TestStand
kill a *.exe from teststand
is it possible to kill (close) a running *.exe from teststand?
regards samuel
(4,000 Views)
Basically, I think you have to do it from somewhere else. Find a DLL that can kill your app (User32.dll maybe?) and then try accessing from TS or maybe write a VI to access it. If you just want to throw money at it, Cyth makes a cute test stand step that has a pretty interface so you can just type in the window title, hit save and when the step runs it closes the desired program.
CLED (2016)
(3,993 Views)
Or is it possible to write a LabWindows programm compiled as *.dll with which I can kill the *.exe? If Yes, Can anyone tell me the command or send me a code example?
regards samuel
(3,986 Views)
see response to http://forums.ni.com/ni/board/message?board.id=180&message.id=25882#M25882
Regards
Ray Farmer
Regards
Ray Farmer
(3,976 Views)
