NI TestStand
Order of execution within a step
I'm fairly new to TestStand, and I am trying to debug an issue with a sequence file.
I have a step, which is a .NET adapter (not sure whether that may be relevant).
Within the properties looping has been enabled, and a post-expression has also been set.
Will the post-expression execute at the end of each iteration of the loop or once, after the loop has iterated 5 times?
Thanks in advance.
Andy
(3,545 Views)
Accepted by topic author AndrewHillier
Look in the TestStand Reference Manual in Chapter 3 under Step Execution.  It should be pretty clear.
Start>>All Programs>>National Instruments>>TestStand>>Documentation>>Manuals>>NI TestStand Reference Manual
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,539 Views)
I found a table in Chapter 3, (Table 3-4). It lays out exactly what order a step is executed in.
The post-expression of a step will execute on every iteration.
(3,531 Views)
