Parallel Model Data Flow Documentation
Hi Forum
I am looking for documentation for the data flow within the Parallel Model, I need to understand how the Data storage between the Main Sequence and Offline Processing works. I tried several approaches documented below to write a few datapoints to the offline processing but I am lost as to what path those datapoints have at the time of processing.
Thanks, Raphael
https://forums.ni.com/t5/NI-TestStand/Access-Locals-x-from-offline-processing/m-p/4105033/highlight/...
https://forums.ni.com/t5/NI-TestStand/Add-Data-stored-in-locals-to-report-with-offline-results/m-p/4...
(1,340 Views)
Hi Raphael,
Here You can find some links (1) (2) (3) , they might be useful for You.
Regards.
(1,113 Views)
