NI TestStand
Parallel thermocouples in NI 9213
Good morning,
How to connect to one of the channels, in module NI 9213, parallel thermocouples to mesure the average temperature of the room? The others channals is occupied for other measurements.
I need to connect compesation resistors ("swamping resistors") for each of the thermocouple wiche are in parallel? How to calculate its values?
(4,259 Views)
Hi herclau,
The question you have posted is really better suited for the Multifunction DAQ forum.  You will likely have better luck posting your question there.
(4,243 Views)
