NI TestStand
Parameters not passed correctly into VI
Hi All
I have a sequence (Calibration - MLC) with parameter values.
And my concern is the EL_Correction_Fact that is not passed correctly into the VI.
Then in Calibration VI, I pass all these parameters as input.
But when I debug and stop when the Calibration VI opens then I don’t see the same values passed into the Calibration VI.
The Calibration VI With Parameter In and Out looks like this
(1,318 Views)
I’d suggest double checking the cluster passing settings of that typedef
(1,314 Views)
I have checked that the Cluster passing is on.
I also saw that each sequence parameter is loaded from Local. So I changed the Local Parameter to 90.
But still, I got a 98 in my VI.
I've checked the variables when it reached the sequence (before entering) Then the Local Calibration Parameter is 98 and not 90 as I set it to be...
How is this posable?
(1,288 Views)
Accepted by topic author Marinuss
I found the issue.
Parameters are loaded by Locals, and locals get values from a property loader in an Excel file.
M
(1,275 Views)
