02-05-2018 01:32 AM
I have a problem. I have a sequence in teststand with one pass/fail step, and I call to a VI.
When I press run main sequence, it starts to run and not finished, it is running all time.
Why?
It isn't the first time that it occurs.
Thanks.
02-05-2018 02:04 AM
Please provide more information, in doubt, add your code (sequence and VI).
I assume that your VI contains a loop which prevents the VI to finish by itself. TestStand is simply waiting for the VI to stop executing.
02-05-2018 02:23 AM
Yes, I have a while loop in my VI.
02-05-2018 02:44 AM
I attach my project.
I have 3 VI, one in FPGA, one in RTMain and one in computer (host)
I'm trying to turn on or turn off a led in sb-RIO trough commands.
I have tried to remove while loops but I don't obtain that I want.
In teststand I'm trying to test the Vi in computer (host.vi) , and i'm obtaining the previous error (which i started this issue)
Could you help me?
Thanks.
02-05-2018 06:50 AM
Looking in your host.vi shows that the developer of that code is rather new to LV. The biggest issue you are running into is that this VI is not stopping by itself nor is stoppable properly by user interaction. The reason is a misconception on how the error wire is used to stop the loop(s). Also i recommend to use only a single loop to use the TCP connection.
Learn about shift register (or feedback nodes) for improving the code of this VI.
02-06-2018 01:23 AM
Could you help me to improve the vi?
