NI TestStand
Remove breakonfirststep in teststand simple user interaface
I am using Teststand simple user interface. When I open the sequence file and enter TestUUTs, Single pass or Run main sequence ,the sequence file break at first step and it won't move to until pressing Resume. Can you please let me know how to remove this breakonfirststep so that sequence file executes as soon as i run it.
Anand
(2,614 Views)
Hi Anand
A similar question (and solution) here.
Steve
(2,602 Views)
Hi Steve,
I need to disable breakonfirststep in Teststand simple user interface , not in sequence editor.
Any way i got it. I have changed the userinterface.xml file in
AppData\Local\National Instruments\TestStand 2016 (32-bit) file location and it worked.
Anand
(2,590 Views)
Hi Anand,
is it for Sequence Editor?
Bharath
Thanks & Regards,
Bharath Kumar
GCentral
(2,554 Views)
