NI TestStand
Pass/fail status (UUT Result) of my main sequence
I would like to have my last step in my test sequence to be a DLL passing to my SQL database a part number, a serial number from “RunState.Caller.Locals.UUT.SerialNumber” and Pass/Fail status of my Test Sequence.
Can I pass pass/fail status of my test sequence to my DLL before execution is completed?
Thank you,
Henry
(4,949 Views)
Accepted by HenryG
Access Pass/Fail status by using RunState.SequenceFailed.  It will be True if the test failed.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,945 Views)
Thank you very much. Henry
(4,937 Views)
