NI TestStand
Passing Parameters from one subsequence to another subsequence
Hello.
From https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YI5HCAW&l=en-SG, it seems you can pass data from main sequence to subsequence. Is it then possible to pass parameters data from subsequence to another subsequence in the main sequence? Thank you.
(850 Views)
Figure out that you should pass from one subsequence to the main sequence, then pass from the main sequence to another subsequence. The naming of the parameters however is quite confusing.
(837 Views)
