NI TestStand
Setting up buttonhit with a pressbutton
How can I achieve the desired outcome? I currently have a LabVIEW-integrated press button that sends binary data to TS through the connector pane. In TS, I've set up a message pop-up and button hit, and I aim to utilize the press button to respond to the button hit without requiring manual mouse clicks.
(1,014 Views)
Hi Adam,
Can you please be more specific about what do you want on a button press.
I assume you mean the message box button click by the user.
(984 Views)
I am utilizing an NI 4080 digital IO to capture an input signal from an LED-BUTTON. My objective is to associate this captured value with a message box button. Rather than manually clicking the button on the message box, I intend to simulate the message box button using the LED-BUTTON input.
(966 Views)
The message box can take user inputs and not from a DIO.
You have to write a custom message box. i.e a VI which will display the message and wait for the DI signal. On receiving the signal it will close.Maybe you can add a time out for worst case.
Call this VI from the action step type or a pass fail step type ( fails when timeout happens).
(955 Views)
