NI TestStand
Passing Parameters to TestStand from VC++
Hi folks,
I'm trying to send parameters to a "MainSequence" test sequence whem executing
them from VC++6.
Say "MainSequence" takes in one parameter, a number called "number". I'm
trying to use code such as
ParameterProperty=m_TestStandEngine.NewPropertyObject(TS_PropValType_Container,FALSE,"",0);
ParameterProperty.NewSubProperty("Number",TS_PropValType_Number,FALSE,"",0);
ParameterProperty.SetValNumber("Number",0,123);
Parametervar.pdispVal=ParameterProperty.m_lpDispatch;
,then sending it out with Engine.NewExecution(.......)
However, on execution, TestStand is coming back with as error "Specified
value does not have expected type".
Can anyone give me some thoughts here?
Thanks!
Dan
(3,346 Views)
Dan,
I have successfully compiled and run some VC++ code that accomplishes what you are trying to do. Actually it looks very similar to your code, so it might just be that the ParameterProperty object needs to be converted to a variant in order to pass it to the NewExecution method.
Here is the code from an example on National Instrument's web site:
TS::PropertyObjectPtr sequenceArgs;
// Passed arguments must be a container type
sequenceArgs = m_engine->NewPropertyObject(TS::PropValType_Container, FALSE, "", 0);
// Create subproperties for new propertyObject
sequenceArgs->SetValNumber("param1", TS::PropOption_InsertIfMissing, 4);
sequenceArgs->SetValString("param2", TS::PropOption_InsertIfMissing, "Hello");
// Create
variant to pass to NewExecution method
_variant_t sequenceArguments(sequenceArgs, true);
// run the specified sequence in the currently loaded file
m_currentExecution = m_engine->NewExecution(m_currentSequenceFile,
(const _TCHAR *)sequenceName, modelSeqFile,
VARIANT_FALSE, TS::ExecTypeMask_Normal, sequenceArguments);
I have attached a simple MFC Operator Interface that implements this call. Also, you'll find the sequence to call in the zip file.
Best Regards,
Azucena Perez
(3,346 Views)
